1 - 9 of 9 Posts
We have a few project quads that we would like to get products for review that everyone is interested in.
We have the Renegade 800, an Outlander 800, Yamaha Rhino 660, Kawasaki KFX700, Kawasaki Brute Force and some others at our disposal. We need some input from you folks as to what products you are on the fence about for any of them that a review may help your decision for.
If you have ideas on products specific to those ATVs or that is generic between all quads, post back so we can help your decision.
ATVT
For the Kawasaki Brute Force you could potentially do the following products for review : Highlifter Universal Radiator (all bikes), Highlifter oil cooler kit, "dial-a-jets" as well. Just throwing out some products that I may purchase later.
i just installed a gorilla 3000 lb winch a few days ago. haven't really used it for anything other than to spool out the steel cable, and spool in the synthetic rope, under the load of the renegade. everything looked ok, but time will tell. the only thing i did was to open up the contactor box and run a bead of rtv to make sure it's sealed up good. there is a gasket in there, but i have it mounted up front (made a bracket to mount off of the fan-to-radiator bolts) and it will definitely see alot of water/mud. i don't think i'll be using it a whole lot, but i'll definitely post any issues that i may run into. btw, i went with th trail series for 2 reasons. first, it's a couple lbs lighter and second, it is geared at 153:1, rather than 136:1 - should be less of a draw on the renegade's charging system. it will wind the rope in slightly slower, but like i said, i won't be using it all that much.
on my foreman, i've been considering doing a disc brake conversion. there are a few companies that offer them, the kit from Extreme looks to have better rotors than the HighLifter kit and has a direct replacement (Arctic Cat) for the pads. also have been thinking about the Warn 424 for it. the renegade has been taking up all of my time and money! ;;s;;
1 - 9 of 9 Posts
