1 - 7 of 7 Posts
well i was riding and decided to go into this one hole i have never been in before.....and guess wat....it started out at like 2 feet deep.....then it was bout 5 feet deep....i caught myself and only my front end went down sucking water into the tranny......then i had to get winched out......then i pulled the drainage plug and holy crude it drained for a good 2 min. What exactly do i need to do for maintance on this since i do have all the water out. I checked my oil it didn't look milky it looked fine but i plan on still changing it.
Everything is up and running great again! The fluids didn't seem to be a problem. The Exhaust was barely in the water and same with the airbox. Really the only thing that went under was the front end.....i kinda caught it before i allowed my rear to drop in also. I took the clutch apart and the grease was flung all over from the water and also the grease was gritty from the murky water. I cleaned it all up then re greased everything and it doesn't sound like a dog hauling like it did after i swamped it.
The grease was flung all over the place when usually its rather clean in here
1 - 7 of 7 Posts
