That sounds like something FST would say. Don't get me wrong, he does good work when it comes to building engines, I just think Mickey can be a little arrogant.
The jet kit is OK, one thing you need to do is to pull the slides and sand them smooth with 1000 grit and them polish them to a mirror shine. Drill 12 1" holes in the air box lid and block off the intake snorkel to the airbox. Check ebay or your local dealer for a set of 02' prairie velocity stacks to replace the ones currenly installed. Finally get a Twin Air pro filter kit.
As for exhaust, you are only looking at 1-2 HP gain with the Pro-Circuit. The Muzzy seems to be the best exhaust for the V force. I definitely produces the most HP out of all that is available.
Finally, if they will sell you one call UPPracing.com and get a UPP intake for the carbs, you will then need to rejet but you'll notice a huge improvement from that point.
Once you are satisfied with the following you can start plaing with the clutch. A Dalton Blue spring is what gives me the best results.
