90cc, 4 Stroke, CVT Fully Auto, Single Cylinder, Air Cooled
Transmission: CVT Fully Auto
Suspension: Dual A-arm
Ignition: 12V,C.D.I.
Starting: Electric
Max Power(Kw/rpm): 4.0 Kw(5.4Hp) / 7500
Max Power(Nm/rpm): 5.6 Nm / 6000 Rpm
Net Weight : 160 LBS
Gross Weight : 214 LBS
L x W x H : 46" x 30" x 33"
S eat Height : 23"
Wheel Base :32"
Tires : ( Ft )16x6-8 with 14" Rim, (Rr)16x7-8 with 14" Rim
Brake : F+R Disc Brake controlled by foot lever only (no hand brake lever)
Max Speed : 25 miles/hr
Petrol Tank capacity : 1.6L (0.423 Gal)
Light : With head light but no tail light
Actual Dimensions - Falcon 110
Length 58 inches
Width 33 inches
Height 34 inches
Net Weight 229 Lbs
Gross Weight 282 Lbs
MODEL Falcon 110 - Chain Drive
Engine 107cc - Air Cooled, 4 Stroke, Single Cylinder
Max Power (Kw/rpm) 5.2/7100
Max Power (Nm/rpm) 7.3/6000
Ignition 12V CDI
Start Electric with a set of keys
Fuel Capacity 4.5 L
Transmission 3 Speed Semi Automatic with Reverse Gear
Suspension Front Shocks-Single A-arm, Rear Mono Shock
Brakes Front Drum & Rear Drum
Seat Height 31"
Top Speed 28 MPH
Tires (Ft)19x7x8, (Rr)19x10x8
Colors Red, Blue, Yellow, Green, Black
Others Head Light, Speed Limiter, Horn, L.E.D. Gear Pos Indicator
Actual Dimensions - Baby Falcon 110
Length 58 inches
Width 33 inches
Height 34 inches
Net Weight 229 Lbs
MODEL Baby Falcon 110 - Chain Drive
Engine 108cc - Air Cooled, 4 Stroke, Single Cylinder
Ignition 12V CDI
Fuel Capacity 4.5 L
Suspension Single A-Arms with Front Shocks / Rear Mono Shock
Brakes Front Drum, Rear Drum
Seat Height 27"
Top Speed 28 MPH
Lacoste 110
http://www.kazumaatvparts.com/2006_Kazuma_Lacoste_ATV_110cc_3_spped_with_reverse_p/0110.htm Actual Dimensions - Lacoste 110
Length 55 inches
Width 31 inches
Height 34 inches
Net Weight 229 Lbs
MODEL Lacoste 110 - Chain Drive
Engine 110cc - Air Cooled, 4 Stroke, Single Cylinder
Ignition 12V CDI
Fuel Capacity 4.5 L
Transmission Clutch Less 3 Speed Semi Automatic, Reverse
Suspension Dual Front Shocks, Rear Mono Shock
Seat Height 26.4"
Top Speed 31.1 MPH
Tires (Ft)19x7x8, (Rr)19x7x8
Actual Dimensions - Dingo 150
Length 59 inches
Width 36 inches
Height 44 inches
Net Weight 348 Lbs
Gross Weight 407 Lbs
MODEL Dingo 150 - Chain Drive
Engine 149cc - Air Cooled, 4 Stroke, Single Cylinder
Max Power (Kw/rpm) 7.7/7500
Max Power (Nm/rpm) 8.5/4000
Ignition 12V CDI
Fuel Capacity 4.5 L
Transmission CVT Fully Automatic, Hand Reverse
Suspension Front Shocks w/ Dual A-arm, Rear Mono Shock
Brakes Front Drum & Rear Disc
Seat Height 31.8"
Top Speed 35 MPH
Tires (Ft)23x7x10, (Rr)22x10x10
Others Full Front & Rear Rack. Rear Brake Light & Towing Hitch
Starting: Electric
S eat Height : 23"
Wheel Base :32"
Length 58 inches
Width 33 inches
Height 34 inches
Net Weight 229 Lbs
Ignition 12V CDI
Fuel Capacity 4.5 L
Seat Height 31"
Top Speed 28 MPH
Length 58 inches
Width 33 inches
Height 34 inches
Net Weight 229 Lbs
Ignition 12V CDI
Fuel Capacity 4.5 L
Seat Height 27"
Top Speed 28 MPH
Lacoste 110
Length 55 inches
Width 31 inches
Height 34 inches
Net Weight 229 Lbs
Ignition 12V CDI
Fuel Capacity 4.5 L
Seat Height 26.4"
Top Speed 31.1 MPH
Length 59 inches
Width 36 inches
Height 44 inches
Net Weight 348 Lbs
Ignition 12V CDI
Fuel Capacity 4.5 L
Seat Height 31.8"
Top Speed 35 MPH
