Oil Filter Info
Motorcycle-Specific Filters - (About 2.5 to 3 inches long)
Purolator Motorcycle ML16817 about $6.00
NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8
AC Delco PF2135 about $10
FRAM PH6017A about $7
STP SMO-017 about $6 Autozone
Amsoil SMF-103
Automobile Filters - (About 3.5 inches long - fit reference 1994 Mazda MX-3, V-6 Engine)
Mobil 1 M1-110 about $10
Bosch 3323 about $5
Purolator Pure One PL14610 (old number was L14620) about $6
NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
Deutsch D-370 about $4
AC Delco PF-2057 about $6
Motorcraft Long Life FL-821 about $4
STP S-02867 about $3
FRAM, Castrol, Penske 7317 about $3
Automobile Filters - (About 2.5 inches long - fit reference Mazda RX-7 and Miata)
Bosch 3300 about $5
NAPA Gold 1365 about $6
Purolator L14622 about $5
AC Delco PF1237 about $6
STP S-02876 about $3
FRAM PH6607 about $3 Plug NGK CR7E
Torque Specs
Drive clutch (Ft) Reverse Threads
69-ft-lb
Secondary drive (Rr) Normal Thread
69-ft-lb
Lug Nuts
58-ft-lb
Spark plug
13N-m / 113in~lb
Belt Deflection
Standard belt deflection 22~27mm (.87~1.06 in.)
The rule of thumb
0.1 mm (0.0041n.) change in spacer (shim) thickness equals about 1.3mm (0.051in.) change in belt deflection
You remove shims to tighten the belt & add shims to loosen.
Kawie Part # on shims
92026-0034 - Shim thickness 0.3mm (0.012in.)
92026-1569 - Shim thickness 0.6mm (0.024in.)
92026-1617- Shim thickness 0.8mm (0.032in.)
90026-1565- Shim thickness 1.0mm (0.039in.)
92026-1570- Shim thickness 1.4mm (0.055in.)
BRUTE FORCE
Brute Force Ball Joints- Dealership will try & sell you a complete knuckle,this isn't necessary V-Force ball joints are an exact fit. ( Tip courtesy Kagey )
V-Force Ball Joints
59266 59266-0013--Upper Part #
JOINT-BALL 4
59266A 59266-1139 --Lower part #
Brute replacement Cv boots
AutoZone - Precision Universal Joint boot, it fits a 1989-1994 Suzuki Swift with a 1.3 liter motor. Cost is $8.99 and comes with grease, 2 clamps
Fan motor Breaker- Part # 21008-0001- Fan not working this is more than likely the culprit. Under the seat with a green reset switch.
Amsoil SMF-103
Bosch 3323 about $5
Bosch 3300 about $5
Torque Specs
69-ft-lb
69-ft-lb
Lug Nuts
58-ft-lb
Spark plug
13N-m / 113in~lb
Belt Deflection
The rule of thumb
BRUTE FORCE
V-Force Ball Joints
JOINT-BALL 4
