Boring a cylinder is pretty straight forward. Since you a boring larger, you will want to send the cylinder off and have the cylinder walls re-coated with nikiasil (spelling?). Once back, the words clean cannot be overemphasized. Wash it extremely well with Dawn soap and then dry, when you can rub the inside of the cylinder with a piece of white paper as if it were sandpaper, and it comes out clean then it is ready for assembly.
During assembly, be sure to use assembly lube. I like the Crane lube, nice and thick with the consistency of molasses.
Why you changing the crank? Unless you are installing a stroker and don't mind wrenching a lot or the crank or bearing is shot, I cannot understand why you would want to split the case.
Instead of splitting the case (unless it is necessary) why not have the heads re-valved with better angling and flowed. You'll get a great bit of ponies out of this mod.
Good luck!
Good luck!
