ALL-NEW BAJACROSS IS ITP’s TOUGHEST TIRE EVER
For 2009, ITP is proud to introduce its most rugged tire ever, the all-new BajaCross. This tire is Baja proven to handle the toughest and heaviest UTV applications, and it performs impressively on 4x4 and utility ATVs as well. An 8-ply rating and 25% stronger construction has resulted in a high level of durability. Our extended-life rubber compound and innovative overlapping tread pattern provides a smooth, predictable ride as well as slow wear characteristics — this is the highest-mileage tire ITP has ever produced! Stepped lugs provide consistent tread edges as the tire wears, for predictable performance throughout the long life of the tire. Wraparound lugs provide improved shoulder protection, while a super deep Rim Guard feature offers the best wheel lip protection in the business. Despite its strength, the BajaCross’s advanced carcass design delivers the most comfortable, trail-compliant ride available. Now available in four sizes: 25x8R-12, 25x10R-12, 26x10R-14, 26x11R-14.
NEW 15-INCH ULTRACROSS IS THE HOT UTV SETUP FOR 2009
ITP is excited to announce its first 15-inch tire offering with the all-new UltraCross, designed specifically for UTVs used primarily on hard surfaces, smooth terrain and at higher speeds.
The low profile, lightweight design features a tightly spaced, overlapping tread pattern that lowers rolling resistance and enhances ride comfort. This tread pattern has been computer-designed to also reduce rolling noise levels. The UltraCross utilizes a 6-ply radial construction and a new, more durable rubber compound to deliver longer wear and enhanced cut resistance. A super deep Rim Guard feature offers the best wheel lip protection in the business. Now available in a 26x10R-15 size.
NEW 15-INCH OPTION ADDED TO SS212 LINE
ITP breaks new ground with its first 15-inch wheel. The latest addition to the popular and proven SS212 line not only represents the biggest ITP wheel yet, it also comes in a unique finish: a rich platinum! This heavy-duty 15-inch SS Alloy wheel is load-rated at 1000 pounds and carries a lifetime structural warranty: if you bend or break it, we will replace it! Buy with confidence! Built using ITP’s exclusive Advancecast process to exacting QS 9000 quality specifications. Sizing is 15x7, and it comes with a custom SS wheel cap.
THERE’S NOTHING ELSE LIKE THE ALL-NEW SYSTEM SIX
ITP does it again with another industry first! The all-new System Six is the ultimate in customization! Interchangeable colored aluminum wheel spoke inserts (in red, blue or polished) provide a vast array of customization possibilities. Match your wheel specifically to your ATV or UTV! Optional inserts sold separately. The unique wheel inserts can also be customized by applying graphics, paint, decals, wraps, etc., for a truly one-of-a-kind look! Raw/blank inserts sold separately. The System Six is available in two finishes: a bright, diamond-cut machined finish with black accents topped with a tough clear-coat, and in a dramatic matte black. This opens up even more customization choices:
select from three standard insert colors (above), then mix and match with the two wheel finishes for a wide range of custom looks. Proven in testing to be the strongest, lightest and best looking one-piece aluminum wheels on the market today! Built using ITP’s exclusive Advancecast process to exacting QS 9000 quality specifications, the System Six is strong, light and distinctively different. It carries a lifetime structural warranty: if you bend or break it, we will replace it! Buy with confidence! Custom SS wheel cap featuring an all-new design is included. Now available in a 14x7 size for ATVs and UTVs.
THE SS312 IS ANOTHER IMPRESSIVE ADDITION TO ITP’s SS ALLOY WHEEL LINE
All new for 2009, the SS312 joins the proven SS Alloy line as one of the strongest, lightest and best looking one-piece aluminum wheels on the market today! The SS312 features a stealthy matte black finish with bright, diamond-cut machined accents topped with a tough clear-coat.
The heavy-duty 12-inch ATV wheel rated at 700 pounds, while the 14-inch side-by-side UTV applications are rated at 800 pounds! The SS312 carries a lifetime structural warranty: if you bend or break it, we will replace it! Buy with confidence! Built using ITP’s exclusive Advancecast process to exacting QS 9000 quality specifications. A custom SS wheel cap featuring an all-new design is included. Sizing is 12x7, 14x6 and 14x8, for precise front/rear fitment.
2009 TUNDRACROSS IS THE INDUSTRY’S FIRST STUDDED TIRE
Leave it to ITP to deliver the ATV/UTV industry’s first production snow and ice tire!
The all-new TundraCross features nearly 100 carbide-tipped steel case studs that are strategically placed for maximum performance on ice and snow. The TundraCross is based on ITP’s highly successful TerraCross R/T XD design, and features fully sipped (thinly cut) lugs, which result in more traction-grabbing edges and maximum traction in loose, slippery conditions.
Its 6-ply bias construction is light in weight and offers excellent flotation to keep the tire “on top” of the snow. A proven Rim Guard keeps snow and ice out of the bead area and protects the wheel lip. The TundraCross debuts in two sizes: 25x9-12 and 25x10-12.
NEW HOLESHOT SxS DELIVERS PROVEN PERFORMANCE FOR SIDE-BY-SIDE UTVs
Legendary ATV track and trail performance is now available for side-by-side UTVs! The all-new Holeshot SxS is designed to be the ultimate short-course UTV racing tire. Super strong 6-ply bias construction helps the UTV track straight and sure under acceleration and braking. Siped (thinly cut) knobs provide more biting edges for exceptional traction and balanced cornering. Unlike many other tires now being used for UTV competition, the Holeshot SxS steers easily, rides smooth and is very light in weight! Now available in two sizes: 25x9-12, 25x11-12.
