Billybob,
A good rule of thumb is; if your going over 2000 ft +/- sea level then you need to adjust your carburetor to make sure you AFR (air / fuel ratio) is correct. Since higher altitudes have less air density (or simply put, less air) then you need less fuel. This is just the opposite for lower altitudes.
Most of the time for ever 2,000 - 2,500 feet above sea level you go you can expect to need to drop one jet size. You can also adjust the clip on your needle jet; or sometimes referred to as the metering rod (this usually only applies to aftermarket needle jets).
Keep in mind that a lot of other environmental changes affect carb tuning and performance such as temp. and humidity; so you may find yourself fiddling around with the tuning a bit to get it just right.
