1 - 17 of 17 Posts
Hi everyone....
What type of wrench are you using to adjust the front and rear shocks on your Grizzly. I went to the local Yamaha dealer and they didnt have any so I went to 2 different cycle/ATV parts stores and bought two different wrenches and they were both the wrong size.
Honestly, the easiest thing to do is skeet some wd-40 down in between the shock and the collar to get everything loosened up. Let it sit for a few minutes to trickle, then grab a pair of big channel-locks, grab the collar and give it the old twisty-twisty. The rears are a little difficult to get onto with the wheel on if your channel-locks are huge like mine. So, you may wanna pull the rear wheels off if yours are large.
I hope that helps.
I have a huge pair of channel locks that I used before but they seem to tear up the edges of the teeth on the adjusting thingy.... Maybe the WD40 is the trick.. I will try that now..
Try jacking up quad to take some of the pressure off too. Might help. Why wouldn't your yami dealer order you the part?
I have it jacked up.. I didnt order the part because the channel locks worked initially and I thought I could find an aftermarket part that would work... But,, I am going to the Paiute Trails this weekend camping and I needed to crank it up some because of the extra weight I am carrying..
Good point BG, i forgot to mention that about jacking it up.
I REALLY would not waste my money on the tool. I would jack it up, use wd and pliers and get-er-done.
Discussion Starter · #7 ·
thanx for the tips.... the lube worked...
That's great!
What happens is dirt and grit gets built up between the collar and the shock and makes it rough to turn without some lube. Ahhh, lube is always good. :beer" So, by skeeting some lube in, you loosened it up and made it easy to rotate with the channel-locks.
I'm glad it worked out and saved you a few bucks at the dealer for an un-needed tool.
Thanks for the tips lads and I will be trying the channel locks too . When I have remembered to ask for this special spanner wrench nobody seems to have one and I've been wanting to try adjusting the springs on my BB to get rid of a bit of roll . Thanks again .
TD
Well I did as was mentioned here and lubed that collar thingy and had the bike jacked up . A set of channel locks and it moved smooth as a whistle . I would have kicked myself for buying that special wrench because it sure is not needed if following these very easy directions and readily available tools . Thanks again .
I'm interested to see now how the BB moves along with the suspension cranked up a bit .
TD
So did you ride it or not. You posted at apparently 4:22AM my time so I'm assuming you didn't ride then but certainly enough time between now and then to give it a spin.
Did you tighten or loosen it?
I'm positive I already gave you my thoughts on how it's working Buster but it must have got deleted .
Anyways I cranked the suspension in, to one notch before max on the back and two below max on the front . So far I have only ripped around the yard and I find it sticks in the corners better without the body roll . I've been busy taking down and hauling trees but have not found any change there nor do I expect to but the real test will come when I take the BB on a two up tour . This is where I had issues with body roll and was often fighting the bars especially running along a side hill . I also think that big quadrax seat ,box I have on the back helps to create much of the body roll while riding two-up because of it's high centre of gravity .
I will be back with the feedback as soon as I get out riding two-up again .
TD
So what's the hold-up, get out and ride.
Glad to know the suggestions helped.
Ahh Buster you slave driver you . LOL .I took the BB for a 45 mile run up some back roads to visit with a buddy and its a run I have done quite a few times . It has some hairpin corners and such and although not my real test of how increasing the tension on the shocks I definately felt there was a difference for the better .
I wish I could give my bride sometime off from work and doing chores around the house to take her on a backcountry tour to really see how much the BB has improved while riding two-up . LOL Maybe next time she will do her chores faster so she can go . LOL
TD
Maybe she's coming up with chores as excuses cuz she doesn't wanna ride. I know mine would do that if I ever asked her to go. Chores would be an easier excuse than just saying I don't wanna go cuz I ain't interested.
Well actually my bride is great for wanting to get out and ride,hunt or fish Buster so no complaints here but mind you I had a couple of brides before her and each one has been better than the previous . LOL
Dang I wish I could get some of the good smilies you guys all have and use . LOL
Anyways since adjusting the shocks up and getting much more ride time on since, I'm impressed with how well the BB handles . She digs so much better in the corners and alot less fighting the bars when riding two up . It even feels sportier if sporty is even possible on a BB . LOL I should have done this adjustment a long time ago .
TD
1 - 17 of 17 Posts
