Fix Powersports Clutch Sheave
Every Grizzly 700 owner that truly rides their quad to it's potential has one thing in common at some point in their ownership. They want more power in the low to mid-range, and wouldn't mind adding a little more top-speed. Since the majority of the folks on our review crew ride Grizzly 700s, we are on a constant mission to gain as much as we can in these areas. With our extensive experience with this particular machine, we're able to identify where the problems with it lie from a power standpoint. The problem is finding a manufacturer that is building a product to alleviate the problem by improving upon Yamaha's original design or just replacing Yamaha's design with their own.
Due to the rapidly growing popularity of the side-by-side market, many after-market product manufacturers of are focusing the majority of their R&D time on that industry. What this means to the quad owner is that getting aftermarket performance products is becoming increasingly difficult, as is our search for more products to improve the power of the Grizzly. So, with this in mind, we looked to the parts available for the Rhino since the drive train is virtually identical to that of the Grizzly. We ran across a growing concept with the Yamaha Rhino as a power improvement that caught our attention. The concept was to redesign the clutch sheave to give the much desired low to mid-range gains. It seemed that along with this also came top-end gains. Never before have we found a product that would produce BOTH results in one product as generally there was a trade-out. If you wanted more low-end power, you lost top speed, and vice versa. The potential of this was very exciting, so we began researching the top names in the business. while some of the companies building a sheave for a 700 Rhino promised only top-speed gains, we found that Rhino's that were fitted with a sheave from
Fix PowerSports, saw the just the results we had been searching for.
Upon initially contacting
Fix PowerSports, our idea was to try to get a sheave designed for a Rhino and put it on the Grizzly. After telling them our thought, they told us in the next few days they would be releasing to the public, a sheave they had built specifically for the Grizzly. Holy cow! We couldn't have contacted them at a better time.
Fix PowerSports is known for, amongst many other performance modifications, their clutch work in the Rhino arena and have been doing R&D on a
clutch sheave they've designed specifically for the Grizzly 700.
Installation of the Fix PowerSports Clutch Sheave
Fix PowerSports provided an excellent set of installation instructions with the product. Although they did not have any pictures included, they were written in a very descriptive manner so as to leave no question in your mind as to what your next step was to entail. They also provided a baggy of an ample amount of grease for you to lube the new sheave and rollers. This is great so you don't have to go buy a overpriced tub from your dealer in a quantity so large that you will never use it all. This installation was a breeze and took approximately an hour and a half from start to finish after allowing time for the lube-work. Here's a si gouggestion though when you get to the greasing portion: Latex gloves, cuz that grease is nasty.
Prior to our test ride after the install, we were excited to see the extremity of the gains from a machined
clutch sheave as we've heard very good things about the improvements the
Fix PowerSports sheave makes on the Rhinos.
Ride Report
My first impression was WOWSER! I had to give a few minutes of break-in and settling the fresh grease into the sheave and around the weights before I noticed the substantial gain. After that, it was quite impressive. It gave some unreal low-end to mid-range additional power.
Let me give you an example of where I really noticed the low-end gains were not some marketing ploy but were indeed facts. Although at times my neighbors don't care for it, I use my street as a test track for certain products. Strap on a helmet, make a quick pass or two and see what I've gained. If it was good, then on the trailer and out she goes for a real ride. Well, on this street there's a flat area that I used to be able to get to a max speed of 50 MPH before running out of room. Well, in the initial phase of testing, I made the same pass in the same area and held it for as long as I could before I had to get out of the gas. What I found was that after installing the sheave, I was able to obtain a speed 4mph faster than with the factory sheave. So what does that say then you ask. Well, it says that the quad is now pulling harder through the low to mid-range so it's able to get to a higher speed in the same distance.
After that, we were convinced it was time to suit up and hit the trails. We ran through a bit of tight cornering areas as well as areas that has some short stretches where we could feel the pull. Getting out of the corners seemed much snappier. At times we had to adjust our riding style as we found the front end coming up more than once by applying throttle as we were accustomed to when exiting a corner. Was this a bad thing? Absolutely not. It was just something we were not accustomed to this often and we had to adjust accordingly. as for top sped improvements, at the time of writing this review, we've not been able to take the quad out to a location as of yet to allow a top speed run. However, we will be doing this soon and update the review accordingly once that final stage of the review is complete.
All-in-all, we have to say that with the
Fix PowerSports clutch sheave on our Grizzly 700, it seems as if we've finally gotten something out of this quad that could make it a serious machine to be up against in a race situation.
From the entire ATV Torture Team, we say thanks to
Fix Powersports for giving us this opportunity.
