Editorial Content
Put your ATV or UTV to work this spring.
With winter all but gone, it’s time to start looking to spring and any maintenance you need to do around your property. To help make your job easier, Polaris offers a number of implements designed to fit Sportsman ATVs and Ranger UTVs.
Polaris’ landscape rake ($349.99) can help you clear trails, groom horse corrals, rake the beach or help maintain a gravel driveway. It features 21 hardened steel rake tines, five positions of adjustability, and 60-inch width. Learn more here.
The hitch mounted material spreader ($1,499.99) is designed to spread large volumes of material as quickly and efficiently as possible. Polaris boasts it distributes fertilizer, seeds, chemicals and other materials evenly. You connect it to your vehicles electrical system to power the spreader motor. Learn more here.
This sprayer features a 60-gallon corrosion-resistant polyurethane tank with a 12-volt diaphragm pump and a pressure gauge that lets you adjust the spray pressure up to a maximum of 45 psi and 3.8 gpm. The unit includes a pistol grip handgun with an adjustable nozzle and 25 feet of hose. The spray gun horizontal throw is 35 feet with a maximum vertical throw of 26 feet. The sprayer ($899.99), which is Roundup ready, installs easily in a Polaris Ranger rear cargo box. Learn more here.
The 40-gallson sprayer ($899.99) shares many features with the 60-gallon version. The main difference is the adjustable boom, which extends out beyond the Ranger. Learn more here.
Polaris says its disc plow ($399.99) is designed to cut through sod, clay and more. It features two individual gangs of four discs and five adjustable cutting angles and a cutting width of 54 inches. Learn more here.
Read more about the Five ATV and UTV Implements for Spring Land Maintenance at ATV.com.
