Morning Desertrat ! :hello: ... The old body mending pretty good ?? Sure hope so Big Guy !
Now to your question ... when you say, a larger extended rear rack ... you're talk'in about it only being extended out the back, right ? Not the sides ?
The only thing I've ever seen like that, is one of those add-on baskets. I've seen some that are flat, but extend rearward & some have like a hanging down portion. You could put like a 5 gal bucket in it & not have to worry about it fall'in off.
Here's one link for the rear extended type basket ..
http://www.sportsmansguide.com/net/cb/cb.aspx?a=319369&kwtid=230486
Here's another one from Cabela's ... it appears to be a tad wider too.
http://www.cabelas.com/cabelas/en/templates/links/link.jsp?id=0013292520991a&type=product&cm_mmc=CRR-_-RLP-_-520991-_-productname_link&cmCat=CRR&cmCat=netcon&cm_ven=netcon&cm_cat=Google&cm_pla=Rear%20basket%20for%20atv&cm_ite=netcon&rid=0180101070502
I used google & typed in "Rear basket for ATV" for my search. Lots out there, but not sure if they are much different than the two above.
Now, these are add-ons, so if you were planing to replace your stock rack, maybe you could cut the mounting points from the damaged factory rack & weld them to one of these ... just a thought.
Good Luck .......
ccasion14:
Later ....
Good Luck .......
Later ....
