1 - 15 of 15 Posts
HTML:
<h1 class="style1">CHOOSING AN ATV HELMET</h1>
<p class="style1">[IMG]http://www.atvtorture.com/images/forumimages/t20b.JPG[/IMG]When it  comes to helmets, the decision to wear one can be a matter of life or death in  the event of a bad spill. So obviously a helmet is the single most important  piece of riding gear an OHV enthusiast can wear.</p>
<p class="style1">
  Those of us  who always wear helmets often wonder what the problem is with folks who refuse  to do so. Modern helmets are actually very comfortable and lightweight,  providing the rider with a lot of confidence and protection from the elements.  Many off-road helmets are also vented, so getting too hot is no longer a valid  excuse for not wearing one. Of course, if you happen to be riding in an area  where it’s against the law to ride without a helmet, well you aren’t going to have  a choice!
</p>
<p class="style1">[url="file:///C|/Users/gary/Desktop/t20b.JPG"][/url]There’s  an old saying in the off-road world, “If you’ve got a $10 head, buy a $10  helmet.” Basically, it’s warning riders to steer clear of the really cheap  helmets. Not all helmets are as effective as the next, and the quality helmet  makers have gone to great lengths to give their customers the best protection  available.
</p>
<p class="style1">In  fact, one of the first things to look for when buying a helmet is to see if it  meets one of the two performance ratings (these are stitched on the inside of  the shell and on the box). The first is the Department of Transportation rating  that shows the helmet meets a certain set of standards as a legal helmet for  street and off-road use. The Snell rating signifies that the helmet goes beyond  the DOT standards and can withstand even harder blows.</p>
  Most  automobile, ATV, and motorcycle racers demand nothing less than a Snell rating  for their headgear. Of course, the higher-quality Snell helmets are going to  cost more, but you should still find plenty choices that are reasonably priced.
</p>
<p class="style1">Now  let’s face it, as with most anything that we wear, looks are an important part  of the buying process. Fortunately, the style and color choices from the  various manufacturers are immense. Start your new helmet search by choosing  several helmet styles and colors in your price range and then begin to compare  features.</p>
<p class="style1">
  Another  important helmet decision is whether you want a full-face or open-face helmet.  Before full-face helmets came onto the market in the early 1970s, dirt bike  riders fashioned plastic mouthguards that strapped onto the bottom of the  helmet. The full-face helmet eliminated the need for mouth guards and virtually  all racers embraced the full-face concept by the start of the 1980s.  Off-highway vehicle riders today buy considerably more full-face helmets than  open-face (full-face helmets are not necessarily more expensive). And common  sense says why [i]not[/i] have the extra  protections of a full-face helmet (your chin and teeth are pretty vulnerable in  an open-face helmet). Full-face helmets combined with goggles also offer much  better protection against the elements than open-face helmets.</p>
<p class="style1">
  The  type of ATV riders who may choose an open face are typically those who utilize  their quads for work or other outdoor recreations, such as hunting, fishing,  ranching, or construction. Being able to have easy access to their face while  wearing their helmet and having the added visibility is a plus. Also, the  chance of having a tough spill is simply not as great as that for a trail rider  or racer.
  There are  also other features you should be aware of while checking out helmets. First  off, check for air vents that can be opened or closed for hot or cold weather.  Then compare the weights (a lighter helmet is much more comfortable during a  long day of riding). You should also check the construction of the visor for  durability. </p>
<p class="style1">
  You may  want a visor that is adjustable to your taste. Many folks who don’t ride assume  that a visor on an ATV helmet is used to keep the sun out of your eyes like a  baseball cap, but the primary purpose of a visor is so a rider can duck and  protect his face from the dirt roost being thrown by the rider in front of him!</p>
<p class="style1">
  Getting a  helmet that fits right is important for two reasons: [i]1)[/i] a proper fit is much more effective in a mishap, and [i]2)[/i] you’ll want to wear it all the time  because it’s comfortable! The best way to check fit is of course to simply try  a lot of helmets on. Also be aware that a medium size in one brand may be more  similar to a small in another. Some of the higher-end helmets are sold in more  precise sizes such as 7 1/4 or 8.
  The perfect  fit for a helmet is as snug as you can get it while still being comfortable.  You should not be able to easily insert a finger between your forehead and the  helmet lining. Similarly, the padding of a full-face helmet should press  lightly against your cheeks, but here you are much more likely to insert a  finger or two. With the helmet in place, try to rotate it without turning your  head. If the helmet turns significantly on your head (especially if it turns  enough to interfere with your vision), it is too loose and you should try the  next size down. If the next size down is too tight, consider trying another  brand, as each helmet manufacturer has fairly unique shell shapes. Without  tightening the chinstraps, shake your head briskly from left to right a few  times. The helmet should follow your head and not come out of place. Same goes  if you move your head up and down quickly.</p>
<p class="style1">
  Now try the  retention strap system. You should be able to easily strap on the helmet you  choose. Once the strap is snug, grab the helmet with both hands and move it  around vigorously. Your head should be moving with the helmet.</p>
<p class="style1">
  If you’re going to be wearing glasses with your  helmet, make sure you try them on at this time as well. You may need a slightly  looser fit in the side of your temples.</p>
<p class="style1">[b][i]Helmet Care[/i][/b]
  With helmets, most feature removable liners that can be thrown into the washing  machine. But to stay on the safe side, don't throw this liner into the dryer;  instead let it air dry. If the liner isn't removable, clean it with soap and  water. Keep in mind, though, that you shouldn't use any solvents on any helmet  materials-the styrofoam inner liner can easily get melted, ruining the most  important part of the helmet. </p>
<p class="style1">
  If you know you are going  to be riding in muddy conditions, you can make the chore of cleaning the outer  shell much easier by applying a thin coat of WD-40 or Armor-All before you go  riding. </p>
Good piece.
One factoid that I believe I have read is that the DOT rating of a helmet is based on specifications and if submitted specifications are in order, the Gubbermint allows the DOT sticker to be used. There is NO, repeat NO physical verification that the actual helmets produced actually meet the specified design. Obtaining a DOT sticker is about as difficult as say, applying for a library card. The resulting helmet is roughly as strong in reality as a silly-putty egg. Sorry.
Snell foundation stickers on the other hand are obtained only after submitting an actual sample helmet which is subjected to minimum impact standard lab testing by an independent non profit organization. There are different standards based on whether it is a M (moto) , or SA ( Car Racing) helmet, depending on the need fire retardant linings and rollbar impact tests. Snell also obtains random production samples which are also tested to make sure that the manufacturer is actually consistenly building the helmet to that standard. If you like the handsome face you shave each morning, go for the Snell rated helmet.
One other piece of helmet reality that folks dont always accept is that in most cases the protective foam inside the helmet is intended for ONE TIME USE as it crushes during an impact and absorbs part of the energy. ( unlike most types of foams that "rebound " the energy) That means that if a helmet has seen an impact it should be tossed instead of re-used, as it now offers less impact protection. How much of a hit does it take ? Its hard to know, since the shell deforms and springs back sometimes leaving the foam inside crushed and you cannot tell from the outside other than a scratch or cracked paint.
When in doubt...toss it. It probably smells bad and doesnt match your new ATV anyways.
Very cool write up. I use a Fox Pro Tracer. Nice helmet.
I had a so/so HJC. It saved my head when I took a spill on my old trike. After that, I bought my next helmet based on the rating. It had to be DOT and SNELL approved. I think you can get a good helmet that's SNELL approved for a little under or arround $100. It's cheaper than a new head. 8)
So I take it this helmet would not make the grade? That is my ugly mug with the skull cap
I have had that helmet since my street riding days in the 90's
It dont help your riding a Artic Cat :sign10:
Guilty as charged GW . I'm notorious for not wearing my helmet and only do so under the the duress of where I may run into the lawdogs on a lake ,roadway or well known trail . Even when out on the coldest days in the winter I just wear my open face helmet where required while the full face fancy shmancy one collects dust on the shelf . I just don't like that full faced one because I have to crane my neck around to see anything behind even though I have mirrors . It also makes me feel claustrophobic . :dontknow:
The only good excuse I can come up with albeit lame is that I drive slow anyways and do wear either sunglasses or safety glasses to ward off branches or stones and dust .
Good write up lad .
TD
I'm thinking about getting a modular helmet (the one's where the chin bar is hinged) because I hate having to take my glasses off every time I put my helmet on or take it off. The thing that concerns me is that the modular helmet has a visor, which by definition excludes the use of goggles. And I don't want to use an open face because you don't get the facial protection you get from a full face. Does anyone on this site use a modular helmet for ATV riding? If so, please supply some feedback.
1 - 15 of 15 Posts
