Sorry I took so long. I would say 5-10 minutes to take it off or on. Finding where to install it and the angle you want the saw at are the biggest parts of the installation process. Once that it done it stays the same and only the "U" bolts are removed to mount or remove the unit. I have not installed wingnuts to the "U" bolts as I don't think you could get your hand under the rack to tighten them enough, a ratchet works fine and gives me better piece of mind.Nice write-up CLHC. It's good to see another person's opinion on this as I've been considering one myself. Is the mount on it as such that it is pretty easily removable. In other words, would it be easy enough to mount periodically if you know you're gonna need it but not have on during times where you doubt you would?
Or, could you use locking wingnuts on it to make it easier to put on or remove?
The more I use this unit the happier with it I am and Kolpin's customer service is excellent.
