ATV PRODUCT REVIEW: Carlisle Mud Wolf Tire
998 Views 9 Replies 3 Participants Last post by  Mulchman
HTML:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
</head>
<body>
<h1>[b]Carlisle Mud Wolf Tire Review [/b]</h1>
Reviewed by Shawn </p>
<h2>[b][url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf First Inspection[/b]</h2>
[IMG]http://www.atvtorture.com/reviews/images/carlisle/product_large.jpg[/IMG]When  you first look at these tires, you can’t help but notice that the  aggressive nature of the tread pattern is like no other out there. The  next thing you notice is the shear girth of the lugs associated with  this aggressive tread pattern. At 1-1/8” deep, these lugs should be a  formidable contender to most tires out there. The front tires measured  in at 9.2” wide and the rears were 11.5” wide. [url="http://www.carlisletire.com/"]Carlisle[/url] advises load ratings not to exceed 410 lbs on the fronts and 520 lbs on  the rears at 50 mph. I wouldn’t worry about this rating, it just  confirms that these tires are not approved for highway use.</p>
Here are the specifications of the [url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf:</p>
• 6 Ply Rated – Resists Punctures Provides  Stability
  • Massive, Deep Lugs – Maximum “Bite”
  • Aggressive  Shoulder Treatment – Side Bite in Rutted Conditions </p>
Before  we give you our ride impression, we have to make mention of their  weight. These 26” tires weighed in at nearly 130 lbs. total! The  fronts were about 28.8 lbs. a piece and 35.5 lbs for the rear. That’s a  lot of weight for a 26” tire. This makes these 6 ply rated tires  relatively heavy when compared to similar ones currently on the  market. The table shown below illustrates the weight of the other [url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf tires and their  respectable sizes.</p>
</p>
<div align="center"></div>
<table cellpadding="0" cellspacing="0">
  <tbody>
    <tr>
      <td colspan="2" align="left" height="94" valign="top"><div align="left">
        <table id="AutoNumber4" border="0" cellpadding="0" cellspacing="0" width="780">
          <tbody>
            <tr>
              <td align="left" valign="top" width="766"><table id="AutoNumber1" border="1" bordercolor="#007b9f" cellpadding="0" cellspacing="0" height="100" width="100%">
                <tbody>
                  <tr>
                    <td align="center" height="44" width="17%">[b] SIZE[/b]</td>
                    <td align="center" bgcolor="#00b1e6" height="44" width="13%">[b] PRODUCT
                      CODE[/b]</td>
                    <td align="center" height="44" width="7%">[b] PLY[/b]</td>
                    <td align="center" height="44" width="11%">[b] MTD
                      DIAMETER[/b]</td>
                    <td align="center" height="44" width="10%">[b] MTD
                      WIDTH[/b]</td>
                    <td align="center" height="44" width="12%">[b] RIM
                      WIDTH[/b]</td>
                    <td align="center" height="44" width="13%">[b] MAX LOAD
                      CAPACITY
                      @ 10MPH[/b]</td>
                    <td align="center" height="44" width="7%">[b] MAX
                      PSI[/b]</td>
                    <td align="center" height="44" width="8%">[b] TIRE
                      WEIGHT[/b]</td>
                  </tr>
                  <tr>
                    <td align="center" height="20" width="17%"> AT25 x 8 - 12</td>
                    <td align="center" bgcolor="#00b1e6" height="20" width="13%"> 537125</td>
                    <td align="center" height="20" width="7%">6</td>
                    <td align="center" height="20" width="11%"> 25.0</td>
                    <td align="center" height="20" width="10%">8.3</td>
                    <td align="center" height="20" width="12%"> 6.50</td>
                    <td align="center" height="20" width="13%">340</td>
                    <td align="center" height="20" width="7%">7</td>
                    <td align="center" height="20" width="8%">27.5</td>
                  </tr>
                  <tr>
                    <td align="center" height="20" width="17%">AT25   		x 11 - 12 </td>
                    <td align="center" bgcolor="#00b1e6" height="20" width="13%"> 537126</td>
                    <td align="center" height="20" width="10%"> 11.6</td>
                    <td align="center" height="20" width="12%">9.00</td>
                    <td align="center" height="20" width="13%">455</td>
                    <td align="center" height="20" width="8%">30.2</td>
                  </tr>
                  <tr>
                    <td align="center" height="20" width="17%">AT26   		x 9 - 12 </td>
                    <td align="center" bgcolor="#00b1e6" height="20" width="13%"> 537127</td>
                    <td align="center" height="20" width="11%"> 26.0</td>
                    <td align="center" height="20" width="10%">9.2</td>
                    <td align="center" height="20" width="12%"> 7.00</td>
                    <td align="center" height="20" width="13%">410</td>
                    <td align="center" height="20" width="8%">28.8</td>
                  </tr>
                  <tr>
                    <td align="center" height="20" width="17%">         AT26 x 12 - 12  </td>
                    <td align="center" bgcolor="#00b1e6" height="20" width="13%"> 537128</td>
                    <td align="center" height="20" width="10%"> 11.5</td>
                    <td align="center" height="20" width="12%">8.00</td>
                    <td align="center" height="20" width="13%">520</td>
                    <td align="center" height="20" width="8%">35.5</td>
                  </tr>
                  <tr>
                    <td align="center" height="20" width="17%"> AT27 x 9 - 12</td>
                    <td align="center" bgcolor="#00b1e6" height="20" width="13%"> 537129</td>
                    <td align="center" height="20" width="11%"> 27.0</td>
                    <td align="center" height="20" width="10%">9.0</td>
                    <td align="center" height="20" width="12%">7.00</td>
                    <td align="center" height="20" width="13%">440</td>
                    <td align="center" height="20" width="8%">31.7</td>
                  </tr>
                  <tr>
                    <td align="center" height="35" valign="top" width="17%"> AT27 x 12 - 12 </td>
                    <td align="center" bgcolor="#00b1e6" height="35" valign="top" width="13%"> 537130</td>
                    <td align="center" height="35" valign="top" width="7%"> 6</td>
                    <td align="center" height="35" valign="top" width="11%"> 27.0</td>
                    <td align="center" height="35" valign="top" width="10%"> 12.0</td>
                    <td align="center" height="35" valign="top" width="12%"> 9.50</td>
                    <td align="center" height="35" valign="top" width="13%"> 550</td>
                    <td align="center" height="35" valign="top" width="7%"> 7</td>
                    <td align="center" height="35" valign="top" width="8%"> 35.7</td>
                  </tr>
                  <tr>
                    <td colspan="9" bgcolor="#66ccff" height="1" width="98%"><p align="right"></p></td>
                  </tr>
                </tbody>
              </table></td>
            </tr>
          </tbody>
        </table>
      </div></td>
    </tr>
    <tr>
      <td align="left" height="50" valign="top" width="598"><div align="left">[IMG]http://www.carlisletire.com/images/pixel.gif[/IMG]</div></td>
      <td width="178"></td>
    </tr>
  </tbody>
</table>
<h2>[b][IMG]http://www.atvtorture.com/reviews/images/carlisle/PC140010.jpg[/IMG][url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf Ride Review[/b]</h2>
It  was evident almost instantly that the weight of these tires did take  some snap out of the bike, but to be fair the same goes for all of the  tires we have reviewed to date that are not stock. With that said, I  could not believe how these tires performed! These tires ate up  anything you fed them on the trails. Mud, rocks, and fallen trees were  nothing for this tire. The tread pattern just continued to grab, bite,  and pull their way through and over most obstacles. </p>
The engineers at [url="http://www.carlisletire.com/"]Carlisle[/url] really did their homework when designing this tire. They gave this  tire a great foot print. A flat profile and unique side lug design  proved tough enough to gain the necessary traction needed to climb,  pull, or grab onto surfaces in all types of terrain. The overall ride  quality of these tires was quite pleasant considering their bias ply  construction. While they may not be as good as some of the radials we  tested, they can by no means be considered uncomfortable. </p>
[IMG]http://www.atvtorture.com/reviews/images/carlisle/PC140007.jpg[/IMG]We  found that these tires really shine at moderate speeds while traveling  trails with tight turns. Trust us when we say that “your buddies will  notice if they follow to close” as these tires throw quite the rooster  tail of trail debris! They continued to perform great in both  off-camber and technical riding scenarios. Whether the trail was muddy,  hard packed or wet, this tire found a way to find traction. You can’t  help but notice how surefooted these tires make your ride feel. They  really give you a very safe sense of control. </p>
Unfortunately, as of this  writing we really haven’t had a chance to test these tires out in that  deep “Louisiana” type of mud. What we can say, is that these tires do  clean out very well in the limited amount of mud we’ve encountered to  date. This we felt was an impressive quality and with that being said,  I could definitely recommend them for moderate mud riding. You can  easily compare these tires to the top contenders in their category and  have no worries when diving into the next mud hole. </p>
<h2>[b][url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf Qualities[/b][IMG]http://www.atvtorture.com/reviews/images/carlisle/PC140013.jpg[/IMG]</h2>
The  jury is still out on the longevity and wear characteristics of these  tires as we have just passed the 500 mile mark. We are pleased to  report that we have reached this milestone without any noticeable  wear. As with any tire, using the correct air pressure is an important  element that has a profound affect on the handling of a machine, and  this tire is no exception. The only down side to these tires, other  than their weight, can be found when driving at high speeds. At speed  these tires tend to ride very rough and that stands to reason since  they are a bias ply, non-highway service tire. So this ride trait  shouldn’t be a big surprise to anyone.</p>
</p>
<h2>[b]Carlisle Mud Wolf Overall Analysis:[/b]</h2>
<h3>[b]Conclusion:[/b]</h3>
  The [url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf has never stopped impressing us. The durable sidewalls have  proven to be extremely puncture resistant. Match this with an equally  impressive tread design and it gives us everything we need in an  extreme terrain situation. If asked whether we would ever consider  another set of [url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf tires, the answer would be a resounding   				YES! I also think that the [url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf tire would also make an excellent choice as a UTV Tire. Keep  in mind that no tire is perfect and these tires do a great job in the  environments they were designed for. As always, just remember to ride  within your limits to avoid risk or injury to both yourself and your  equipment. </p>
</p>
<h3></h3>
<h3>[b]Pros[/b]:</h3>
<ul type="disc">
  [*]Extremely       tough design
  [*]Puncture       resistant
  [*]Rim       guard
  [*]Excellent       tread pattern cleans easily
  [*]Made       in the U.S.A.
  [*]Center       lug offers good ride
[/list]
<h3>[b]Cons[/b]</h3>
<ul type="disc">
  [*] Heavier       than most in it’s class
  [*]Side       lug appears to be spaced a little close for maximum performance
[/list]
For more information on the [url="http://www.carlisletire.com/"]Carlisle[/url] Mud Wolf tire contact [url="http://www.carlisletire.com/"]Carlisle[/url] Tire Company or visit you nearest [url="http://www.carlisletire.com/"]Carlisle[/url] Tire dealer.</p>
 [url="http://www.carlisletire.com/corporate/contact.html"]Carlisle Tire Contact [/url]</p>
</body>
</html>
1 - 10 of 10 Posts
Great review... been waiting to read it. :icon_thumleft:
A couple of questions... What size were you testing? I saw the widths mentioned, but how tall did they measure?
reedin iz hard :BangHead: The sad part is that in my original post, all I asked was about their true height, then I couldn't remember reading what size you were testing and I edited the post.
What is their true mounted height?
I am not sure. We will get some measurements for you .
I am going to put a set of these on my Kodiak 400. I have already bought the following to boost power: EPI clutch kit for 26"-27" tires, jet kit, unifilter, HMF Utility Series exhaust, and front locker.
Sorry, forgot to say that the size will be 26x9 front & 26x12 rear. I am not into hauling a$$ on the trails. I like to ride at a good pace, enjoy the scenery. I also like to enjoy the occasional mudhole, hence wanting to buy the Mudwolf's.
Does anyone think I will have a problem with these tires?
Wayne
Wayne
So far to date we have yet yo have any problems with the Mud Wolfs. They are a heavy tire though.
Thank you sir for the quick reply. I should have clarified my question though, my fault.
I know I will lose some power because of the heavier tires. But, with the mods I listed that will go on the Kodiak. Do you think I will still have the same power as it was stock with the stock tires, or will I still have some power lose? I am hoping with all the mods I will still be somewhere near stock power or a little more power.
Again thanks for the quick reply. Next time I will try to be a little clearer with my questions.
Wayne
You may still notice a slight power loss with the mods mentioned. The only reason I say this is because the 700 Grizzly tested really had nothing to compare against. Since the day it was purchased it had either 27" Mud Lites or 26" Mud Wolfs.
Thanks again sir for the reply. Hopefully the power loss will not be too noticable.
1 - 10 of 10 Posts
