Cat, can you give a little more info about the situations when it stalls out?
If you just leave it sitting idling, does it stall? Or is it right off the start with just barely giving it throttle or does it stall at high RPM ranges? For example, the 07 and 08 Grizzly was prone to stall right off the start if you only gave it a little juice and it was fuel injected.
If you can tell us more about how much throttle it is being given when it stalls, that will help to diagnose. If it doesn't do it at a certain point every time, please give details about that as well.
