Hi,
I thought I could figure this out myself, but now I realize I can't figure out the correct scheme.
I have a simple light switch, with a pole switch to the ceiling fan and a light in the bedroom.
I want to install a Cabinet light with a pull-out chain to light up a dark closet in the hallway.
I have easy access to the current light switch box (the easiest start) or to the fan box. (not so simple)
Right now, the circuit is a power supply to a light switch box, connected neutrals, and a single-pole switch between points and normal bases.
I know I can turn on the light from the ceiling fan, but then I will need to turn on the switch in the bedroom to turn on the light in the closet.
Is there an easy way to do this, if you answer, can you provide a quick drawing.
Thank you very much,
