1 - 4 of 4 Posts
2010 Can-Am Renegade 800R EFI
Standard package features:
  • Rotax 799.9 cc V-twin EFI engine with 71 hp
  • RS-type double A-arm front suspension with dive-control geometry and 8.5-inch (216 mm) travel
  • RS-type TTI rear suspension with 9-inch (229 mm) travel
  • Fade-resistant HPG shocks
  • Visco-Lok auto-locking differential
  • Lightweight center-cast-aluminum wheels with ITP Holeshot∞ ATR sport radial tires
  • Separate front and rear brake controls
  • Multi-purpose digital gauge
  • Four 60W projector beam lights
  • Full floorboards with kick-up aluminum pegs
Manufacturer Suggested Retail Price (MSRP): $9,699 US
what is the hp diff 09 vrs 2010 renny and how did they get it. is there any low end top end issues like between 09 vrs 08. was it a type error on the diff gas tank size or is the 2010 a gallon smaller. any other diff that can be discussed between 08 vrs 2010 rennyXxc
Here are a couple of differences between the 2009 X and 2010 Xxc:
Dry Weight:
2009 - 607lbs
2010 - 614lbs
Fuel Capacity:
2009 - 5.3 u.s gallons
2010 - 4.3 u.s gallons
Stator output:
2009 - 400 watts
2010 - 650 watts
Power Steering:
2009 - no
2010 - yes
Improved vsco-lok performance from 09 to 10.
Bore & stroke is the same between the two years as is throttle body size.
As for pipe fitment and such, i don't see any reason why the 2010 would require a different exhaust than the 2009. The 2010 parts catalog is not up yet so I can't check part numbers to see if the 2009 and 2010 exhausts are the same number. If they are, that would answer that question and I'm guessing they will be.
1 - 4 of 4 Posts
