1 - 4 of 4 Posts
The 2008 Arctic Cat ThunderCat H2 EFI 4x4 Automatic SE is a Utility Style ATV equipped with an 950cc, Liquid / Air Cooled, V Twin, SOHC, 4-Stroke Engine and a Continuously Variable (CVT) Transmission. It has a Selectable 4X2 / 4X4 driveline. The ThunderCat H2 EFI 4x4 Automatic SE has a Independent Double A-Arm Front Suspension with 10 inches of travel while the Independent Double A-Arm Rear Suspension has 10 inches of travel. The ThunderCat H2 EFI 4x4 Automatic SE has Front Hydraulic Disc Brakes and Rear Hydraulic Disc Brakes. The ThunderCat H2 EFI 4x4 Automatic SE was introduced in 2008 and is New for 2008. It includes a 6 month Limited warranty.
Arctic Cat ThunderCat Dimensions
Length (in): 84.8
Width (in): 47.5
Height (in): 49.3
Wheelbase (in): 52.5
Ground Clearance (in): 11
Arctic Cat ThunderCat Capacities
Fuel Capacity (gal): 6.5
Arctic Cat ThunderCat Weight
Dry Weight (lbs): 716
Payload Capacity (lbs): 300
Towing Capacity (lbs): 1050
Arctic Cat ThunderCat Engine
Displacement (cc): 950
Engine Type: V Twin
Starter: Electric / Pull
Cylinders: 2
Engine Stroke: 4-Stroke
Arctic Cat ThunderCat Front Suspension
Front Suspension Type: Independent Double A-Arm
Front Travel (in): 10
Arctic Cat ThunderCat Tires
Front Tire (Full Spec): AT 25 X 8-12
Rear Tire (Full Spec): AT 25 X 11-12
Arctic Cat ThunderCat Driveline
Driveline Type: Selectable 4X2 / 4X4
Rear Unlocking Differential: No
Arctic Cat ThunderCat Transmission
Primary Drive (Rear Wheel): Shaft
Reverse: Yes
Transmission Type: Continuously Variable (CVT)
Arctic Cat ThunderCat Seat Specifications
Number Of Seats: 1
Arctic Cat ThunderCat Rear Suspension
Rear Suspension Type: Independent Double A-Arm
Rear Travel (in): 10
Arctic Cat ThunderCat Brakes
Front Brake Type: Hydraulic Disc
Rear Brake Type: Hydraulic Disc
Arctic Cat ThunderCat Price
MSRP: $10499
Warranty (Months): 6
Several memebers on AC Chat have them. Incredible power. handling is claimed by them to be much better than previous models. One memeber opened it up on a dirt rode and claimed 80 mph and still a bit to go.
1 - 4 of 4 Posts
