1 - 3 of 3 Posts
The 2008 Arctic Cat ThunderCat H2 EFI 4x4 Automatic SE is a Utility Style ATV equipped with an 950cc, Liquid / Air Cooled, V Twin, SOHC, 4-Stroke Engine and a Continuously Variable (CVT) Transmission. It has a Selectable 4X2 / 4X4 driveline. The ThunderCat H2 EFI 4x4 Automatic SE has a Independent Double A-Arm Front Suspension with 10 inches of travel while the Independent Double A-Arm Rear Suspension has 10 inches of travel. The ThunderCat H2 EFI 4x4 Automatic SE has Front Hydraulic Disc Brakes and Rear Hydraulic Disc Brakes. The ThunderCat H2 EFI 4x4 Automatic SE was introduced in 2008 and is New for 2008. It includes a 6 month Limited warranty.
Arctic Cat ThunderCat Dimensions
Length (in): 84.8
Width (in): 47.5
Height (in): 49.3
Wheelbase (in): 52.5
Ground Clearance (in): 11
Arctic Cat ThunderCat Capacities
Fuel Capacity (gal): 6.5
Arctic Cat ThunderCat Weight
Dry Weight (lbs): 716
Payload Capacity (lbs): 300
Towing Capacity (lbs): 1050
Arctic Cat ThunderCat Engine
Displacement (cc): 950
Engine Type: V Twin
Starter: Electric / Pull
Cylinders: 2
Engine Stroke: 4-Stroke
Arctic Cat ThunderCat Front Suspension
Front Suspension Type: Independent Double A-Arm
Front Travel (in): 10
Arctic Cat ThunderCat Tires
Front Tire (Full Spec): AT 25 X 8-12
Rear Tire (Full Spec): AT 25 X 11-12
Arctic Cat ThunderCat Driveline
Driveline Type: Selectable 4X2 / 4X4
Rear Unlocking Differential: No
Arctic Cat ThunderCat Transmission
Primary Drive (Rear Wheel): Shaft
Reverse: Yes
Transmission Type: Continuously Variable (CVT)
Arctic Cat ThunderCat Seat Specifications
Number Of Seats: 1
Arctic Cat ThunderCat Rear Suspension
Rear Suspension Type: Independent Double A-Arm
Rear Travel (in): 10
Arctic Cat ThunderCat Brakes
Front Brake Type: Hydraulic Disc
Rear Brake Type: Hydraulic Disc
Arctic Cat ThunderCat Price
MSRP: $10499
Warranty (Months): 6
Discussion Starter · #2 ·
2008 Arctic Cat 700 EFI 4x4
The 2007 Arctic Cat 700 EFI 4x4 Automatic is a Utility Style ATV equipped with an 695cc, Liquid / Air Cooled, Single-Cylinder, DOHC, 4-Stroke Engine and a Continuously Variable (CVT) Transmission. It has a Selectable 4X2 / 4X4 driveline. The 700 EFI 4x4 Automatic has a Independent Double A-Arm Front Suspension with 10 inches of travel while the Independent Double A-Arm Rear Suspension has 10 inches of travel. The 700 EFI 4x4 Automatic has Front Hydraulic Disc Brakes and Rear Hydraulic Disc Brakes. The 700 EFI 4x4 Automatic was introduced in 2007 and is New for 2007. It includes a 6 month Limited warranty.
Arctic Cat 700 Weight
Dry Weight (lbs): 713
Arctic Cat 700 Engine
Displacement (cc): 695
Engine Type: Single-Cylinder
Cylinders: 1
Arctic Cat 700 Front Suspension
Arctic Cat 700 Tires
Rear Tire (Full Spec): AT 25 X 10-12
Arctic Cat 700 Driveline
Arctic Cat 700 Seat Specifications
Number Of Seats: 1
Arctic Cat 700 Transmission
Reverse: Yes
Arctic Cat 700 Rear Suspension
Arctic Cat 700 Brakes
Arctic Cat 700 Dimensions
Length (in): 84
Width (in): 47
Height (in): 49
Wheelbase (in): 50
Ground Clearance (in): 12
Arctic Cat 700 Capacities
Arctic Cat 700 Price
MSRP: $7599
2008 Arctic Cat Prowler 700H1 4x4
The 2008 Arctic Cat Prowler 700 H1 4x4 Automatic XTX is a UTV Style ATV equipped with an 695cc, Liquid / Air Cooled, Single-Cylinder, SOHC, 4-Stroke Engine and a Continuously Variable (CVT) Transmission. It has a Selectable 4X2 / 4X4 driveline. The Prowler 700 H1 4x4 Automatic XTX has a Independent Double A-Arm Front Suspension with 10 inches of travel while the Independent Double A-Arm Rear Suspension has 10 inches of travel. The Prowler 700 H1 4x4 Automatic XTX has Front Hydraulic Disc Brakes and Rear Hydraulic Disc Brakes. The Prowler 700 H1 4x4 Automatic XTX was introduced in 2008 and is New for 2008. It includes a 6 month Limited warranty.
Arctic Cat Prowler Front Suspension
Arctic Cat Prowler Tires
Front Tire (Full Spec): AT 26 X 9-14
Rear Tire (Full Spec): AT 26 X 11-14
Arctic Cat Prowler Driveline
Rear Unlocking Differential: Yes
Arctic Cat Prowler Seat Specifications
Number Of Seats: 2
Arctic Cat Prowler Transmission
Reverse: Yes
Arctic Cat Prowler Rear Suspension
Arctic Cat Prowler Brakes
Arctic Cat Prowler Dimensions
Width (in): 61.3
Height (in): 77.5
Wheelbase (in): 75
Ground Clearance (in): 12.5
Length (in): 115
Arctic Cat Prowler Capacities
Fuel Capacity (gal): 8.2
Arctic Cat Prowler Weight
Dry Weight (lbs): 1165
Payload Capacity (lbs): 325
Towing Capacity (lbs): 1500
Arctic Cat Prowler Engine
Starter: Electric
Cylinders: 1
Arctic Cat Prowler Price
MSRP: $10999
1 - 3 of 3 Posts
