The 2008 Arctic Cat Prowler 700 H1 4x4 Automatic XTX is a UTV Style ATV equipped with an 695cc, Liquid / Air Cooled, Single-Cylinder, SOHC, 4-Stroke Engine and a Continuously Variable (CVT) Transmission. It has a Selectable 4X2 / 4X4 driveline. The Prowler 700 H1 4x4 Automatic XTX has a Independent Double A-Arm Front Suspension with 10 inches of travel while the Independent Double A-Arm Rear Suspension has 10 inches of travel. The Prowler 700 H1 4x4 Automatic XTX has Front Hydraulic Disc Brakes and Rear Hydraulic Disc Brakes. The Prowler 700 H1 4x4 Automatic XTX was introduced in 2008 and is New for 2008. It includes a 6 month Limited warranty.
Arctic Cat Prowler Front Suspension
Front Suspension Type: Independent Double A-Arm
Front Travel (in): 10
Arctic Cat Prowler Tires
Front Tire (Full Spec): AT 26 X 9-14
Rear Tire (Full Spec): AT 26 X 11-14
Arctic Cat Prowler Driveline
Driveline Type: Selectable 4X2 / 4X4
Rear Unlocking Differential: Yes
Arctic Cat Prowler Seat Specifications
Number Of Seats: 2
Arctic Cat Prowler Transmission
Reverse: Yes
Transmission Type: Continuously Variable (CVT)
Primary Drive (Rear Wheel): Shaft
Arctic Cat Prowler Rear Suspension
Rear Suspension Type: Independent Double A-Arm
Rear Travel (in): 10
Arctic Cat Prowler Brakes
Rear Brake Type: Hydraulic Disc
Front Brake Type: Hydraulic Disc
Arctic Cat Prowler Dimensions
Width (in): 61.3
Height (in): 77.5
Wheelbase (in): 75
Ground Clearance (in): 12.5
Length (in): 115
Arctic Cat Prowler Capacities
Fuel Capacity (gal): 8.2
Arctic Cat Prowler Weight
Dry Weight (lbs): 1165
Payload Capacity (lbs): 325
Towing Capacity (lbs): 1500
Arctic Cat Prowler Engine
Displacement (cc): 695
Engine Type: Single-Cylinder
Starter: Electric
Cylinders: 1
Engine Stroke: 4-Stroke
Arctic Cat Prowler Price
MSRP: $10999
Warranty (Months): 6
