The 2007 Arctic Cat 700 EFI 4x4 Automatic is a Utility Style ATV equipped with an 695cc, Liquid / Air Cooled, Single-Cylinder, DOHC, 4-Stroke Engine and a Continuously Variable (CVT) Transmission. It has a Selectable 4X2 / 4X4 driveline. The 700 EFI 4x4 Automatic has a Independent Double A-Arm Front Suspension with 10 inches of travel while the Independent Double A-Arm Rear Suspension has 10 inches of travel. The 700 EFI 4x4 Automatic has Front Hydraulic Disc Brakes and Rear Hydraulic Disc Brakes. The 700 EFI 4x4 Automatic was introduced in 2007 and is New for 2007. It includes a 6 month Limited warranty.
Arctic Cat 700 Weight
Dry Weight (lbs): 713
Payload Capacity (lbs): 300
Towing Capacity (lbs): 1050
Arctic Cat 700 Engine
Displacement (cc): 695
Engine Type: Single-Cylinder
Starter: Electric / Pull
Cylinders: 1
Engine Stroke: 4-Stroke
Arctic Cat 700 Front Suspension
Front Suspension Type: Independent Double A-Arm
Front Travel (in): 10
Arctic Cat 700 Tires
Front Tire (Full Spec): AT 25 X 8-12
Rear Tire (Full Spec): AT 25 X 10-12
Arctic Cat 700 Driveline
Driveline Type: Selectable 4X2 / 4X4
Rear Unlocking Differential: No
Arctic Cat 700 Seat Specifications
Number Of Seats: 1
Arctic Cat 700 Transmission
Reverse: Yes
Transmission Type: Continuously Variable (CVT)
Primary Drive (Rear Wheel): Shaft
Arctic Cat 700 Rear Suspension
Rear Travel (in): 10
Rear Suspension Type: Independent Double A-Arm
Arctic Cat 700 Brakes
Front Brake Type: Hydraulic Disc
Rear Brake Type: Hydraulic Disc
Arctic Cat 700 Dimensions
Length (in): 84
Width (in): 47
Height (in): 49
Wheelbase (in): 50
Ground Clearance (in): 12
Arctic Cat 700 Capacities
Fuel Capacity (gal): 6.5
Arctic Cat 700 Price
MSRP: $7599
Warranty (Months): 6
