Not to say or in any way rank the stock shocks as inferior.But with my wieght and my riding style the stock shocks just didnt cut it. So I did what I always do make something out of nothig.I found that front shocks off a YFZ 450 fits the front of my brute and they work great, the only problem is the ride hight changed in the front because the 450 shocks are longer and with the power of the brute and the wieght distributed more to the rear the front wanted to lift at high speeds.Now I have a problem I cant afford remote resevior shocks, so this is where something from nothing comes into play.With all four shocks off the quad I noticed the front are 1 inch longer than the rear. I also noticed the rear shocks are stiffer than the front. Time for the old switcharoo. I took the springs off the rear shocks put them on the front shocks made a spacer to take up for that extra inch of shock and now because the shock is taller in the rear and the valving in the front shock is better for rebound my brute sets higher front and rear doesnt pull in the front doesnt try to buck you off in the woops and handles great all for the cost of a set of used shocks.
